To: jrschafluetzel
Oops, Typo!
You should be all set jrschafluetzel. Let me know if you any problems with the new username.
~Rach
How can i change my Thwack username?
Hi cdumont@mraresults.com,
I can help with this. What would you like your username changed to?
DH
Would like to change my username to vijay09
VJ
Hey vijay.das,
I can change your username to vijay09. Is there any other detail you would like to change or just the username?
Thanks Maria... Just username...
Regards,
Done.
I need to change my username also. Can one of the admins help me with this?
Hi apilkerton@csbs.org,
I'll DM you.
Hi, Can my username be changed to "kevin.stanton" please
thanks
Hey kevin.stanton,
It's done.
Can some please change my user name?
Currently its showing my email address. Wasnt clear that it would be public :-(
Techno
or
T3chno
if possible.
David
t3chno
David, your username is now T3chno. Be sure the next time you login you type this in as your username.
If you have any other questions, please do not hesitate to reach out!
Can I get my username changed to kevin.b or kbecerra84. Thank you.
kbecerra84
Your username is now kbecerra84. Let me know if you have any other questions or concerns
