Hi All,
I have configured SNMv3 on my HP J8693A ProCurve Switch 3500yl-48G. Every time Cirrus polls the device, "SNMP Security access violation from xx.xx.xx.xx" message is logged on the switch. HP says that such a message is logged every time something is tries to poll the device with the wrong username and password. Since Cirrus always gets the data I request and it also reports the credentials as valid. I suspect the problem is in the way it polls the device. I believe that Cirrus uses something like "let's try this first and see what I get and then based on the information I will try something else" approach until it gets what it wants. This approach generates loads of log messages.I am not an snmpv3 expert and really I do not want to dissect the SNMP traffic bewteen Cirrus and the switch in order to analyze whether Cirrus uses a nice and clean approach and provides the switch with complete and correct information right from the start so the device should not have any issues with it. My common sense tells me it could be one of the following:
1. My bad snmp configuration on the switch - I configured that according to the documentation provided by HP
2. It might be bad SNMPv3 HP implementation as well (personally I doubt it).
3. As stated above - the aproach used by Cirrus.
a) Has anyone experienced the same issue?
b) Is there any workaround available?
c) Can anyone confirm that I am worng regarding the "suspicious" behaviour of Cirrus?
I look forward to you replies.
Many thanks,
Ge0rge
