How do I monitor the system times on all my windows servers that are joined to active directory and then send me an alert when the time is off by more than five minutes from my domain controller? I'm running NPM and SAM.
It just occurred to me that we recently updated this template. Attached is the latest version of that template. Please delete the template from your server and import this one in its place and give it another go. Let me know if that resolves the issue.
The following templates should help you monitor clock drift of your servers
Server Clock Drift (Perl)
I did see those in the built in templates, but when I went to assign them to a server they were not able to poll anything.
Does your Orion server have internet access? Does it require a Proxy?
The Server Clock Drift (PowerShell) template should just work without much effort against a Windows host. If it's not working for you then please open a case with support so we can troubleshoot the issue properly.
Thanks, that worked
