Is there an easy way to remove the help button for the webconsole?
Wrong help.... the small help button on each object on the web page.
Not sure how to remove it, but you can change it and it would just pull up an error page. I believe this is new to 8.1.0. Go to Admin --> Orion Settings and look for Help Server. Put in something like http://127.0.0.1
Ok... I got it removed, just changed the icon to a blank one and bingo, it no longer visable.
Ah, sometimes the simplest things are too hard to see.
Sorry to be late to the party - where is it that one would change the icon to a blank? Do you mean in the folder of images on the server?
(netperfmon\images)?
