Hi to all,
I have 300+ Unix servers and they all have these volumes that I don't want monitor. How can I get rid of them? I don't want to delete one by one. If it is possible with the SQL, anybody kind enough to share the query?
I got a little creative with the above query, but I wanted to make sure that the Node Name and the Volume Name were displayed before you deleted the information to prevent accidental deletion. This query should Translate over very easily for Interfaces or Nodes as well.
I think going to settings-->Manage Nodes and selecting volumes is not going to help here. Would you open a support ticket to get the SQL Query and please post back the ticket# along with the solution.This should be a great help to this community.
I opened a case like you suggested.(Case # 282804)
Thank you and will be great to see the SQL query posted back.
Response from SolarWinds Support
--Run this SQL Query to generate the delete statement
select 'Delete from Volumes where Volumeid=' as [Deletion Script], V.VolumeID, '--', Nodes.Caption as [Node Name], V.Caption as [Volume Name] from Volumes v inner join Nodes on V.NodeID=Nodes.NodeID where V.Caption='/proc/bus/usb' or V.Caption='/proc/sys/fs/binfmt_misc'or V.Caption='/var/lib/nfs/rpc_pipefs' Order by Nodes.Caption, V.Caption--Once this has been executed, run the results if the Caption of the Node Name and the Volume name correspond to what you want to delete--Run this after running the deltion statement generated from the 1st sql query. This will remove the volume from being polles.DELETE FROM Pollers WHERE (NetObject LIKE 'V%') AND (SUBSTRING(NetObject, 3, 10) NOT IN (SELECT VolumeId FROM Volumes))
I tried. It works! Thanks.
Thanks for your help Sean.
