This is my all time favorite post... Now that I found it again I'll have to give this another shot in 8.1
If anyone gets it to work in 8.1 post your code...
I would LOVE to get this implemented in our setup. I tried following the instructions above but the Java app fails to load once I click on the 'S'. PLEASE is there anyone who can help me with this...
This is my all time favorite post... Now that I found it again I'll have to give this another shot in 8.1If anyone gets it to work in 8.1 post your code...
I followed Ian's Excellent instructions and with a few changes got this to work in 8.1.
I downloaded the AdvancedNodeDetails.resource from the customer download area on the solarwinds.net site here http://support.solarwinds.net/support/Unsupported.cfm?Option=Orion. There is a readme.txt in that download that covers installing it and altering the view to use it instead of the standard details resource.
Then I made the below modifications to that file(01-AdvancedNodeDetails.Resource) where it had text links before, because I liked the icons...but you can keep the text if you like.
<tr> <td class="Property" width="10"> </td> <td class="PropertyHeader">Telnet</td> <td class="Property"> </td> <td class="Property"><a href="telnet://<%=Node.GetProperty("IP_Address")%>"><img src="images\Small.telnet.gif" mce_src="images\Small.telnet.gif" alt="Telnet to <%=Node.GetProperty("IP_Address")%>" Border=0></a> </td> </tr> <tr> <td class="Property" width="10"> </td> <td class="PropertyHeader">SSH</td> <td class="Property"> </td> <td class="Property"><a target='_blank' href="">thwack.solarwinds.com/.../SSH.asp mce_href="")%>"><img">thwack.solarwinds.com/.../SSH.asp src="images\Small.SSH.gif" mce_src="images\Small.SSH.gif" alt="SSH to <%=Node.GetProperty("IP_Address")%>" Border=0></a> </td> </tr> <tr> <td class="Property" width="10"> </td> <td class="PropertyHeader">Web Browse</td> <td class="Property"> </td> <td class="Property"><a href="http://<%=Node.GetProperty("IP_Address")%>"><img src="images\Small.goto.gif" mce_src="images\Small.goto.gif" alt="Browse to <%=Node.GetProperty("IP_Address")%>" Border=0></a> </td> </tr>
Then I followed Ian's steps 3 and 4.
I changed the code(shown below) in step 5 a little to match the options in the latest version of mindterm and to make it resize the window and allow the menu when doing the ctrl+right mouse click. Still save it as explained by Ian as SSH.asp.
<HTML>
<SCRIPT>
window.resizeTo(600,800);
</SCRIPT>
<APPLET CODE="com.mindbright.application.MindTerm.class"
ARCHIVE="mindterm.jar" WIDTH=100% HEIGHT=100%>
<PARAM NAME="server" VALUE=<%=CStr(Request("ip"))%>>
<PARAM NAME="cabinets" VALUE="mindterm.cab">
<PARAM NAME="sepframe" value="false">
<PARAM NAME="debug" value="false">
<PARAM NAME="menus" value="popN">
</APPLET>
</HTML>
Then I followed steps 6, 7, and 8 per Ian's guide.
I had to make sure that my browser was set to use the Java JVM and not the MS JVM as the latest mindterm does not support it. After that it works great!
A great big thanks to Ian for spending the time to figure this out!
Make sure your browser is set to use Java JVM instead of the MS JVM. With the MS JVM selected it will just say the applet has been started but display nothing in the browser window.
Thanks so much, this was the problem. Thank you for the detailed procedure!
I am trying to follow your wonderfully detailed instructions, but I have obviously missed something along the way
When I click on a node in Orion to see the details, I get the following error where I would expect to see the links for telnet, ssh...
Microsoft VBScript compilation error '800a0408'
Invalid character
/NetPerfMon/Resources/2-1-NodeDetails/01-AdvancedNodeDetails.Resource, line 94
Response.Write(Node.GetProperty(" mce_href="thwack.solarwinds.com/.../
SSH.asp?ip=<%=
Node.GetProperty("IP_Address"))-------------------------------------------------------------------^
Note: Not sure if the location of the ^ underneath is
significant, but in my browser,
it appears right under the ? between SSH.asp?ip=
John
Do you get the same message if you try to visit the following in a browser?
(replace 'YourServername' and 'NodeIPAddress' with the appropriate information)
YourServerName/.../SSH.asp
I am trying to follow your wonderfully detailed instructions, but I have obviously missed something along the way When I click on a node in Orion to see the details, I get the following error where I would expect to see the links for telnet, ssh... Microsoft VBScript compilation error '800a0408' Invalid character/NetPerfMon/Resources/2-1-NodeDetails/01-AdvancedNodeDetails.Resource, line 94Response.Write(Node.GetProperty(" mce_href="thwack.solarwinds.com/.../
Does the "Response.Write(Node.GetProperty(" mce_href=""))"">thwack.solarwinds.com/.../SSH.asp line appear anywhere in your 01-AdvancedNodeDetails.Resource file?
Does anyone have this configured for version 9.0 SP1? I tried the instructions posted on this topic but when I get to \Inetpub\SolarWinds\NetPerfMon\Resources\2-1-NodeDetails\01-NodeDetails.Resource I do not have anything called
<% SWToolsetIcon "Telnet",Node.GetProperty("IP_Address")%><% SWToolsetIcon "PING",Node.GetProperty("ParamString")%>
Has anyone added the SSH icon from scratch using this new version? I wonder if things have changed with the new version and it has moved but I would like to be able to add the SSH icon next to the Telnet icon on the Node Details page if possible.
Thanks.
<a href='' target="_blank"> <img src="/Orion/images/ToolsetIntegration/Small.SSH.gif" alt="Open an SSH session to " title="Open an SSH session to " /></a>
Looks like part of this is missing. Don't you need to reference the hostname or IP address somehow?
Thanks qle for that information. I will give it a try and see what happens.
Well I started trying the solution and after reading further on the very first post I noticed he was using MindTerm. We use SecureCRT so now I am at a stand still. I have tried to figure out what he did using MindTerm but cannot seem to recreate it using SecureCRT. Does anyone have an SSH shortcut under node details that uses this? If so would you please help get me in the right direction?
Thanks for any help.
Hi all,In my case, I followed Ian's instructions with some changes:Step 1) Open \Inetpub\SolarWinds\Orion\NetPerfMon\Controls\IntegrationIcons.ascx as qle posted above and add:<a href='<%= string.Format("SSH/SSH.asp?Server={0}", this.MyNode.IPAddress) %>' target="_blank"><img src="/Orion/images/ToolsetIntegration/Small.SSH.gif" alt="Open an SSH session to " title="Open an SSH session to <%= this.MyNode.Name %>" /></a>
Step 4) Create "C:\Inetpub\SolarWinds\Orion\NetPerfMon\SSH". It will give me error on Java mindterm.jar if I follow Ian's (C:\Inetpub\SolarWinds\NetPerfMon\SSH.) Dunt know why???
Step 5) Made change in SSH.asp:<PARAM NAME="server" VALUE=<%=CStr(Request("server"))%>>
Another thing, if you want to make the Telnet icon workable, you also have to modified IntegrationIcons.ascx (in step1):<a href='<%= string.Format("telnet://{0}", this.MyNode.IPAddress) %>'> <img src="/Orion/images/ToolsetIntegration/Small.Telnet.gif" alt="Open a Telnet session to <%= this.MyNode.Name %>" title="Open a Telnet session to <%= this.MyNode.Name %>" /></a>
Good luck!
