AHA! I've just discovered where to setup IP Address Groups. This may be the solution.....
Did you find a solution to this problem? I'm also interested in finding the top talker(s) on a subnet?
we have resource for IP Address Group for interface detail view, but it's not there by default. You need to customize view and add resource [Top XX IP Address Groups].
Or other possibility is to create query by [Traffic Builder]. On NTA Summary View you should have resource [Traffic View Builder]. You can choose Node, Interface and there you can add filter for specific IP Address Group.
Is this what you need?
Regards
ET,
Thanks for the reply (I seem to be working you hard today!)
I tried to use Traffic View Builder but I couldn't seem to restrict the view to a subnet e.g. 192.168.99.0 / 24. It seemed to only offer Class A, B or C groups. My whole network is a subneted class B so not very useful.
Similar problem with the IP Address Group Resource.
Thanks again
Andrew
