Is it possible to move content from one View to another? I know you can move between tabs on one view, but it would be nice to move charts from page to page, as well.
By point and click in the routine SolarWinds web page? Not that I have ever seen.
There is the dbo.Resource table - if you are brave enough.
What content are you trying to move from what view, and which view are you wanting to move it to? Orion is extremely flexible and customizable, so it's very likely possible.
I'm trying to move some charts from custom summary to the main summary page
You can easily add that same resource to the Main Summary page but there is not currently a way to copy or move an existing resource from one view to another without having to delete and then recreate that resource on the view you would like to see it.
aLTeReGo Is this still not possible? Would save me an awful lot of time.
What you describe is not really possible today. serena is working on some major improvements to the view management system, so it's good that she better understand your use case. For now though, you'll need to decide what is more work. Adding and configuring resources to that view, or copying the view which has the resources configured to your liking, replacing the existing view with that copy and then making any necessary additional tweaks.
It would be also nice to copy views or resources in a view from a system to another one. Doing something in our lab requires a lot of side by side cut & paste & tweak to our prod system, while a simple export/import feature would save us many hours in a year. (Especially when you are trying to recreate something that was done a while back, not knowing which resource was used at first...)
