Is it possible to move content from one View to another? I know you can move between tabs on one view, but it would be nice to move charts from page to page, as well.
By point and click in the routine SolarWinds web page? Not that I have ever seen.
There is the dbo.Resource table - if you are brave enough.
What content are you trying to move from what view, and which view are you wanting to move it to? Orion is extremely flexible and customizable, so it's very likely possible.
I'm trying to move some charts from custom summary to the main summary page
You can easily add that same resource to the Main Summary page but there is not currently a way to copy or move an existing resource from one view to another without having to delete and then recreate that resource on the view you would like to see it.
aLTeReGo Is this still not possible? Would save me an awful lot of time.
Thanks for bringing this to my attention. Are you only wanting to move charts or other resources/widgets as well?
Thank you aLTeReGo.
My use case is actually moving the resources on the first tab of a view to a new tab on that same view. I have a custom dashboard setup for a critical application at our company. I created this a while back but I have been asked to overhaul it and separate out compute, storage, network, and application performance by tabs. Most of these resources are charts from SAM and SRM.
