Uses a proprietary binary DB- to make it small and fast. You cannot query it or access it.
HTH
That's correct. ipMonitor is intended to be a quick and simple, all-inclusive but entry-level network monitoring solution. If you are looking for something more extensible/scalable, then you'll need to consider Orion.
Yes, that sounds like an ideal scenario for ipMonitor. Just curious, what are your trying to monitor?
Thanks! That satisfied my curiosity Let me know if you have any additional questions.
