Hello,
Does anyone have instructions on how to monitor a Cisco ASA ipsec vpn connection?
Thanks.
You will need to setup a custom poller from the relevant OIDS in the CISCO CRAS MIB
Hello tolinrome
What metrics are you looking for? Is it the NCM compliance side of things you're after, the traffic analyses (NTA), QoE stats using a NPAS, or just 'is it up' (NPM)?
Hi and thanks for the response. As of now, just looking for the monitor for "is it up" thats it.
Then it's NPM, sir.
Moving to the appropriate forum.
Jiri
You got anymore details on how to do this for my friend who is SNMP stupid? What are the relevant OIDs?
Anytime I need OIDs I go to the manufacturer's website to find the OID information or I do a search for the OID through the UDP in the MIB Tree:
If you have access to the Engineer's ToolKit you can do an MIB Walk to better find the OID's for your specific device. It makes life much easier.
