By making the integration of VMAN with NPM, VMWare vCenter appears in gray and the message "status is unknown"
The connection to the VCenter in VMAN is ok
NPM 11.5.2
VMAN 6.3
IVIM 2.1
VM template in the virtual environment was being presented with the VMAN error logs.
Made exclusion of this VM in the virtual environment and reconnection of VMAN.
Hey mate. Check you have all the correct ports open between your primary poller and the VMAN.
Check this link for details
I suspect there's one or two missing.
The system is functioning normally on both servers VMAN and NPM
Sure, I was referring to the connection between NPM and VMAN. You may have completed the integration, and what ports you have open were enough to complete that step, but there might be some missing that is stopping the data from being displayed in Orion correctly. You need:
TCP 17778: For communication with the Orion server if the integration with Orion is enabled.
Are you seeing any error messages when clicking on the VIRTUALIZATION tab in the Orion website?
The TCP 17778 VMAN -> NPM ok
In the attached image VM2.png is demonstrated Virtualization tab.
Error "status is unknown"
Thanks for showing the testing Fenando. Much appreciated. 'status is unknown is certainly not the most useful of error codes!.
Check this SolarWinds KB article.See if it applies to your environment.
If this doesn't help, I suggest you log a ticket with SolarWinds via your customer portal login. I'm all out of ideas!
OK
thank you
Hi Fernando
I am facing the same error , Can you please guide me how to resolve this issue "VMware vCenter status is unknown"
om
The vCenter has not been polled recently
SolarWinds Online Help
