Is there any plan to support Alaxala devices in Kiwi CatTools?
http://www.alaxala.com/en/index.html
HI Chito - I haven't had the request before, but I've entered it as a feature request.
--Christine
Hi Christine-san,
Thank you for the reply.
We have a plan to borrow Alaxala devices from ALAXALA Networks Corporation next month for 2-3 weeks.
Hi Chito - when you get the devices, if you could send us a capture from the device(s) we can then evaluate whether that will be sufficient to add support or if we will need more information, or if we will need to be able to directly connect to them. Please let us know - we would like to work on this with you.
Thank you very much for the reply.
I will send you the capture file after I get the devices.
And if you need to directly connect to the device, we will be able to assist you:)
In Japan, there are a lot of Alaxala users. Also, existing CatTools users hope that CatTools adds Alaxala devices support.
Thank you!
We are ready to use Alaxala 3530S. We can use it to create the script until April 4.
How should I send you the capture file? Should I open a case?
Hi Chito - thank you so much! Yes, if you could open a case, I will tell support to expect it and they have a special system to make it very easy to upload files.
Thank you for your help!
I opened a case(Case #227806) and sent the capture file.
Also, we can use AX1240S from Mar 23 to Apr 4.
