Good Day Guys
I just have a question or two for my own sanity on understanding my SolarwindsOrion Database.
For what reason would the SQL Server Process only use 4GB of RAM but looking at the AppInsight for SQL it shows differently.
Based on the data shown it appears that SQL may be installed on a 32bit operating system, or that you are using a 32bit version of SQL installed on a 64bit operating system.
Thanks aLTeReGo
That is what I thought as well initially, but they are both x64 platform.
Screenshot's below. So I am wondering why it would report 4GB RAM usage for the process.
Can you trying changing the "Platform to run polling job on" for that application from x86 to x64, wait a few polling periods and see if that resolves the issue?
Hi aLTeReGo
Changed it this morning, but the results remains the same though.
Are there multiple SQL Instances running on this server? Also, what does Task Manager report for memory (Memory - Working Set). A screenshot of all memory usage related to this process would be helpful.
The Server is physical and it only runs SolarwindsOrion Database Instance.
We also run the Solarwinds Netflow DB tool on this server.
Server Specifications is as follows.
2x 4 Core 3.3 GHz CPU (we switched of Hyper Threading to test possible performance issue)
8x SSD HDD in a RAID 10 split into multiple partitions for logs, DB, OS and FlowsDB.
64GB RAM but SQL is limited to 48GB RAM.
Screenshots of Task Manager, Resource Manager and some results from Ignite.
