Quick question Denny. Does this summary change also affect the way the IP Address groups can be used. In 1.0 I was able to view an aggregation of all interfaces based on IP Address groups. Now I can only view an IP group while looking at an interface.
I liked the aggregation capability because we use equal cost multipath links for each of our sites and the groups gave me a way to see all the traffic coming from a site. Is there a way I can "hack" this back in? For instance, specify two interfaces (across different nodes) instead of just one. I tried many different things but I've had no such luck.
--Dan
I don't think you can hack it. We are considering putting this back in for a future release.
What if we were to add back only the Top XX IP Address groups to the NetFlow Summary views? Would that solve your issue?
If I could then drill down into the group that would be great. The issue I have is determining our "bandwidth" hogs across the two equal paths.
OK. I'll see what we can do.
