Where can I find the filter that I need to fix for the following report?
Could you elaborate on what you are trying to filter on for this report?
Thank you for helping me out.
What we ran into is a report that does not seem to work. From our "Home" screen we click reports, expand "Historical Traffic Reports" and select the report "Total Bytes Transferred by Node - Last 7 Days". we get a page that indicates the following:
It is a bug. What you will need to do is add the interface ID from the select Fields Tab- and make sure that it is above the Total Bytes Received field.
That worked for that report and I fixed the report for 7 days, last month and this month. However there is yet another report that I need your help to fix. Average and Peak Traffic Rates - WAN Interfaces Last 7 Days does not show any info.
I was running it from a web interface.
I just went into Report Writer from Net Perf Mon and hit the execute button. The window is now stuck with an Hour glass, the box indicates "formatting data..." It began counting down and is now stuck at 3000 records.
