Hi all,
i have installed new additional poller. the installation is completed.
but on HA deployment summary it showing red. can i know what is causing this status
it showing active. but the icon is red.
thanks.
Also, are ALL 4 of those servers actually licensed as Additional Pollers (VCENE2ESWPOLL03, VCENE2EWPOLL04) are showing Active and look to be Active as Primary APE Servers. Are VCENE2ESWPOLL05 and VCENE2ESWPOLL06 supposed to be APE's or are they supposed to be the HA-Standby servers?
I'm just guessing here, but I suspect that the reason they are red is that they are not licensed as Active Additional Polling Engine's, and I suspect maybe you've installed the wrong thing on the standby server and set them up as APE rather than Standby Servers to protect the APE's
Is there a description on the right-hand side of the screen when you select the machine? Are you getting the same error for your APE and your APE HA? Do you have available HA License?
Hi David,
My HA pools is working normally healthy.
the only issue. why is my normal APE is showing red on the page you can see below it showing "Active". but when checking on polling engine page. all is showing green. is there is anything related or need to be configured to make it green? or it related to database ?
Hi Mistik,
The status in your HA Deployment screen is specific to the High Availability compatibility checks. The fact your Polling Engine shows Active and Green in the Polling Engine page just means the APE is working and running as a Poller. It could be that the High Availability service is stopped or not working properly, it could be that the ports required between your Primary Server and the APE for HA are not open? You need to allow port 5671/TCP.
It's hard to be 100% as your screenshot is only a fraction of the screen, can you share a screenshot of the entire page with your APE selected? As on the right-hand side of the screen, it shows some additional information such as:
Status, Last DB Update, Server Type, HA Role, Polling Completion, Elements
The critical status means that the pool member cannot host High Availability resources, but it's still in communication with the rest of HA pool. This could mean that some services on that Polling Engine aren't running or that there is a problem with RabbitMQ on your main Orion server. Just a theory and not a definitive diagnosis.
here i share the printscreen
here the status for additional APE HA, both are okay. only the new additional poller is showing issue.
Are all APEs on the same subnet?
Was this issue solved?
Hi All,
thanks for the support.
i have done reactivate back APE.. then the issue is solved.
thaks for all the assistant.
you are correct. user didnt activate and once i reactivate the licences it become green and ready to go!
how did you reactivate the licenses ?
Please tell me, I am facing the same issue with my standy by server
It's likely the license is activated by not assigned to the polling engine. You can verify this by going to [Settings > All Settings > License Manager]. There you should find your APE license. Ensure it's assigned to your APE.
Thanks for your response, APE license is assigned. So the polling engine
icon is green, but i am trying to create a pool where my stand by server
icon is red. Should i check for HA license as well?
If you have an HA license you should enter in the License Manager screen as per comments above. The only other reason the Pool Member would show RED in the Deployment screen is if the server isn't compatible (ie non-matching applications etc)
