I would love to have my UDT Port Details chart also show the port description. Is there a way to get it to show this?
If you mean the Port Details resource on the UDT Port Details view, then it is already there:
Is that not what you are referring to? If not, then you may need to create a web report and display it as a resource on the desired web view.
Kind of. that is the field I am referring to, but I want it in this chart. I'll check out the web report angle. angle.
I am also looking to do this, helps when trying to find a certain port.
Not included in the current product but I wanted that enough to make it. I wanted a mix between the NPM interface list and the port details resources so I created a left tab called interfaces and put on a custom SWQL query resource which combines them both and does include interface description and UDT seen Hostname/IP's.
Any chance you would be able to share this on Content Exchange?
I created an idea for this. Please vote for it so they will implement it.
would be really helpful if you do.
