Is there a document out there describing best practices for backup/restore of a NPM and NCM environment?
Generally:
What are you wanting to backup and do? Are you moving to a new server?
There are some docs on this page here that may help
Also, we have some native tools we ship in Orion under Advanced to backup some Orion settings
The sysadmins here are looking to create a step-by-step restore procedure for rebuilding our Orion installation in the event that either the NPM/NCM server or the DB server dies.
They are already backing up the database using their normal MS SQL server backup procedures, but what we don't have is a procedure for a) reattaching the server to the database if the DB server is rebuilt, or b) reinstalling NPM and NCM and getting the front-end working again if the application server dies (for example, what data needs to be backed up on the application server to ensure a successful restore, and how should it be restored during the rebuild/restore process).
Did you ever get an answer to this question? I'm preparing for a disaster recovery test right now and having recovery documentation for NPM would be a huge help.
So the application will have to be reinstalled and reconfigured? I was really hoping for a way to simply restore and maybe relicense it.
If you are neither uninstalling NPM/NCM nor changing the NPM/NCM server, running the Configuration Wizard should suffice.
I neglected to mention that if you are changing the NPM/NCM server, you should use License Manager to ensure your license gets carried over. For more information, see "Maintaining Licenses with License Manager" in the SolarWinds Orion NPM Administrator Guide (.pdf).
I think original question was about DR-type of restore from backup/image/snapshot of the server onto new physical/virtual box. I would be interested in that as well, especially from the licensing point of view (does the license need to be re-applied after restore).
helo
i would like to kno this as well
thanks
