Can you elaborate?
Yes
I would like to Inject the reason for big gap in the stat.
It probebly could be done with some DB tricks but i would like to know if solarwinds have tool to fixs that?
Its inportent when the SLA info is getting to 3 part out side the company (custemeres, partner)
Hi Sja,
It is not possible to inject it into the graph.
However if you had alerts go off during this time then you can information when you are acknowledging the alert.
Thanks Melanie
But I not worry about Alerts ,
I realy would like to "publish" at there isnt any stat. data in that time because of...
Hej Pepole
