Has anyone been able to capture flows from the new vcenter distributed switch in vSphere 5? I can add the hosts and the vcenter as a source, but never receive any flows.
Are you be able to see the flows on Orion NTA port 2055 ?
run wireshark to see if flows hitting to Orion from switch source . you need to add Vcenter switch as a node in Orion NPM to recognize the flow from source .
I would like to get this to work also. Did you have any luck making it work?
A packet captur off the NTA server would be golden.
NTA is showing the following error when I add a vm to the distributed switch.
" NetFlow Receiver Service [ORIONSERVER] is receiving a NetFlow data stream from an unmanaged interface on vcenter. The NetFlow data stream will be discarded. Please use Orion Node Management to manage interface '#131' in order to process this NetFlow data stream, or just use Edit this device."
I have setup the distributed switch so the traffic appears to come from the vCenter server instead of coming from each vSphere server individually. How do I add interface #131 to NPM so I can monitor it with NTA?
Anyone have any ideas?
Hi dregier--
I have this marked for the PM to review.
DH
