I am running version 5.1.1 and see that my node icons all show as unmanaged, i.e. they are light blue with an "x" through it.
I also notie that if I select Unmanage for the node, it turns gray, but stays gray when I re-manage it.
Is this a bug?
Does clicking the refresh button in the uppper right-hand corner of the node list control update the status?
No it doesn't. And I tested this on an installation of 5.1. No problem there.
Chris, do you have any additional thoughts on this?
Can you right-click in the tree, choose "Select Fields and Grouping", and ensure that vendor icon isn't at the top of the list?
Vendor is not at the top of the list of available grouping properties.
If Vendor Icon isn't at the top of the Selected Properties, this looks to be a new bug. Please open a support ticket on this and reference this thread.
