Anyone have an idea? I just started searching for an answer this morning, I looked through release notes and the admin guide. Sorry if this has been answered already.
D
Hi Amneese,
What do you mean by "what happened"? Does it mean that it is missing on your NPM 10.5 installation?
Pavel
Correcto, it's gone. Is there another means for custom report creations? During a Solarwinds call last week the engineer stated that she thought it was not in 10.5 and apparently she was correct.
If you are talking about main poller and not additional web or additional poller installation, where it has no sense to be, then I would suggest you to create a support ticket because missing Report writer is not expected behavior.
Cheers,
Thanks for the input. So you can 100% say that the Report Writer should be included in Orion NPM 10.5? Are you currently running NPM 10.5 and have Report Writer?
I do too, but actually I was wondering what happened to the web-based reporting tool that was in the first two RCs of 10.5. Why did SW decide to stick with the old Report Writer?
