how do you create a real time radial dial for cpu usage on a specific node?
On the NODE DETAIL page, click the Customize link in the top right of the page and add the "Average CPU Load & Memory Utilization" element.
Thanks for the info – is there a way to get the gauge to report real time info? I have to refresh the page for an update
On the main page, look in the top right corner for SETTINGS. On that page, click Web Console Settings and set the Page Refresh to your desired time frame.
thanks again – on more question – I got it set on 1 minute – can I go lower than that? It is our main server and would like to see a refresh every few seconds
No. If you want real time stats, just RDP into that server and watch the Task Manager for CPU usage.
Ok – thanks again
