I have setup a Parent map and linked a child map to it. When an interface on a switch goes down you don't get notified on the parent map only when the hole node goes down. Anyone have a work around?
good deal. Once you get one in place, it isn't too bad to replicate and re-map objects.
admin -> web console settings -> Status Rollup Mode
check help if questions about what selection does what.
I've already tried this setting and it's not working. Any other ideas?
hm, that should have worked - my understanding. Another thing to try is "show child status" on the map to child object, but that will just show a little dot in bottom right corner.
I would open a ticket. Please post the results.
It works if the whole node goes down but not just a port. I opened a ticket and it looks like it's not supported which seems like a pretty common request.
Gates--
Would you mind posting your ticket #? I will mark this for the PM to review and move to the NPM Feature Request forum so the community can chime in with their thoughts on this request as well.
Thank you,DH
Sure here you go - 280468
