I am trying to schedule reports and email them as PDF or JPG but I seem to only be able to send it as html...
Questionario,
You should find the information you need in the "Creating Reports" chapter of the SolarWinds Orion NPM Administrator Guide. To create a report as a .pdf, refer to the "Exporting Reports" section of that chapter, and to create a scheduled job to send the report as an email, refer to the section, "Using Report Scheduler > Creating a Scheduled Report Job".
well, I know how to create/export a report as PDF and I know how to create a schedule to have it emailed...
However I want it emailed as PDF (or jpg or whatever), not as HTML...
I'm interested in this also. Did you work it out?
yea... you can EITHER export it as a pdf once (with normal reports only) OR email a certain webpage as email.
However if you send it as an email, it will have incorrect links in the HTML email.
However Solarwinds says this is wanted behaviour, apparently they like errors that annoy customers.
Anyhow, no way to schedule to send a pdf report via email according to solarwinds!
See here for more info on scheduling PDF in what we are working on
great, any estimated date for public availability?
