which system administrator are you talking about?
I also noticed the lsass.exe process taking a ton of cpu-time on my orion server sometimes...
There are also some trojans that can cause this to happen... also if it's a DC:
support.microsoft.com/.../842382
Here is a list of malwares that uses lsass.exe http://www.file.net/process/lsass.exe.html So, malware is also a possibility.
i doubt its a virus/trojan and its not a DC.
Virus scanner is installed and nothing but Solarwinds products have ever been installed on the server, internet security is on high and nobody surfs on that computer.
Have you upgraded to APM 3.5 RC? It should be in your portal now.
We just upgraded to ALX on APM, I have added several monitors and now the server is almost constantly at 100%, most of it coming from this lsass.exe process.
Any solution to this?
EDIT:
I opened a ticket with #159443
I was told the solution is to either wait for NPM v10 and upgrade to Win2008 R2 or wait for APM 3.5 to release.
*vents*
Until then... I guess we just have to delay go-live of solarwinds again.
Its only been 7months anyhow... not quite the ~1hour until its ready... and a lot of wasted money for support, if I knew I would have waited a year for the purchase.
*/vents*
