What's an easy way to change all of our alerts so they point to a different SMTP server? I am having a bear of a time finding where that info is stored.
Thanks for any help!
Does this help?
When I look in the alerts table, I see no reference to SMTPserver in any field. I had seen that message, but figured something had changed with the newer versions.
The SMTP server information is stored in the Target column of the AlertActions table.
Sedmo, when I look in my AlertActions table, what I see in the Target column is To:alertrecept@myco.com but no reference to what smtp server to use.
I think I see the problem DataJunkie. Are you using the Solarwinds Database Manager to query your tables? I notice when I use this tool to query the database it does not show all of the data in the Target column. If I use SQL query analyzer or the SQL Server Management Studio to query the database then I see all of the data in the Target column.
That did it. I had been using MS SQL to look but my SQL expert used your suggestion and we are golden now.
Thank you!
NOTE: TO CHANGE SMTP SETTINGS:
Run the executable located on the Orion Solarwinds server at the path:
<System Root>\Program Files (x86)\SolarWinds\Common\SWEmailNotify.exe
Hello -
Does anyone have a link to Admin / User documentation on how to use [SWEmailNotify.exe] to change SMTP settings globally for all my existing alerts.
Regards,
Peter
