Just noticed that IPM 9.0.4 was released - the download from the support portal contain 9.0.2.
I have the memory leak issue which 9.0.4 addresses (related to smart groups and the multistatus webpage/webview). I would desperately like to try this new release.
http://www.solarwinds.com/support/ipMonitor/docs/ReleaseNotes/releaseNotes.htm
Thanks in advance.
Go to www.solarwinds.com then click on the "customer portal" link.
Once logged in, go to "download your software". There is a download icon that downloads the install file.
Note: the installer indicates "9.0.3", but it is 9.0.4 (known issue).
It appears that the memory leak has been fixed, 9.0.4 has been working as expected so far.
oops - sorry about that. It looks like it will be available tomorrow.
Actually, we should have the 9.0.4 bits on the portal later today. The release notes typically go on the web coincident with the bits, but we're a little behind right now. Please bare with us and check the portal tomorrow morning.
FYI, 9.0.4 should be available in your portal now.
Hi Chris
Where in the portal should we see the update? It's not listed under Product Updates > Archived Service Packs.
BTW, thanks for adding the daylight saving fix!
Rgds, Simon
Thanks legend.
