When I try to import flash I get an error
This happens when on both plugin and active x. I have just downloaded the files from Adobe so they are the latest files. Am I doing something wrong?
Adobe released Flash 18.0.0.209 just few moments ago on the distribution page. Can you check the Flash player EXE version you are using is of the same version of Flash player Package you are trying to import to.
Flash 18.0.0.209 packages will be available in the catalog shortly.
It is the same name. install_flash_player_18_active_x.exe and install_flash_player_18_active_x.msi Same for the plugin. On the download page on adobe it says
Flash Player 18.0.0.203 which is the package I am trying to import.
Sometimes Adobe updates the links in distribution page before the lables. The EXE used might be of version 18.0.0.209. Checking on EXE's properties->details would work.
Below page will be updates as soon as 18.0.0.209 made available in catalog. You can run a synchronization to get them in your console.
Table of third party patches - updated 07/14/2015
When will the Solarwinds packages be updated to show version 209?
Simon
I have been refreshing constantly to see if it was released myself.
New Flash, Shockwave, Reader and Acrobat versions released today by Adobe. Also new Google Chrome is out and supposed to be new JRE releases today.
I am still not seeing it in Solarwinds. Has this been updated yet?
I got packages for Shockwave, Flash, Acrobat and Reader this morning. But still waiting on Chrome and JRE packages. :-(
