I have 2 pollers and after NPM SP4 both are showing about 1000+ less elements. Is this by design?
Of course. We had a defect in 9.5, which we resolved with SP4 whereas for Thin AP's we were adding the virtual interfaces automatically, one for each channel. This was incorrect, our intention was not to charge you licenses for Thin AP's we charge you for the controller. So we had users seeing their interface license count ticking up quite a bit after applying 9.5 with alot of wireless. Hopefully that makes sense
From when? 9.1 or earlier 9.5?
9.5 SP3 to SP4
Do you have a bunch of wireless? If so, most likely that is the reason.
Yes we do. Can you expound on that please?
Great explanation thank you!
