Yes, we are running one remote poller across a WAN to the DB server.
Here are our specs:
So how many elements do you have on that remote poller? What's the latency between it and the DB server? What are your settings for polls, statistic collection, etc?
Sorry for the questions....just seeing how different your set up is to mine. Thanks.BB
I'd be interested in how you have this working as well.I've tuned my polls per seconds below the recommended values & my polling completion percentage has increased from 98.6% to 99.1% for the remote poller.I now have it running across a lightly loaded OC12 WAN link (622mbps) to the DB with 36ms latency.However I still only record SNMP data every 1-2 hours in the CPU, Mem & Utilization graphs.
Thanks for any assistance.
apparently the "head geek" is going to do a webinar on this subject. see the top page thwack.com to register.
FYI
No...I think that webinar is talking about how to use Orion to monitor your WAN links....we are talking about how to get Orion to work with pollers of WAN links.
I tweaked the time the poller issues pings for up/down; rediscovers and stuff but that didn't help. I still have alot of gapping (dots on graphs) on my remote poller. I have to make a decision soon on what to do but my WAN link is very good and I don't see how its any different from what you have.BB
Bryan, are you seeing gaps in just SNMP collected data, or ICMP as well?My ICMP polling charts are fine (polling every 5 minutes).This proves that it can be done without gaps in the data.
I'd be interested in how you have this working as well.I've tuned my polls per seconds below the recommended values & my polling completion percentage has increased from 98.6% to 99.1% for the remote poller.I now have it running across a lightly loaded OC12 WAN link (622mbps) to the DB with 36ms latency.However I still only record SNMP data every 1-2 hours in the CPU, Mem & Utilization graphs.Thanks for any assistance.
NG...you say you tuned BELOW the recommended value? Was that the one provided by the polls per sec program? I'm getting ~96% completion rate on my 2 remote pollers (ones across the WAN). BB
