I need to know how to export my reports into Excel format please
Gerjan,
Actually, you can modify the report.asp file (at least until the next major release, when Orion no longer supports custom asp resources.) At one point, there was a description of how to do this in the content exchange area. You have to add a line to the report.asp file (in the \inetput\SolarWinds\NetPerfMon folder.) In the sub DoReport, you add the following before the first <% End If %>.
<td align=right><a href="<%=URL%>&Printable=TRUE&dataformat=XLS"><img src="/NetPerfMon/images/Button.RawData.gif" border=0></a></td>
Just for the record, I'm not an asp developer, but this is working in our environment (v9.1 SP3.) This has been working for us since v8.5.1, but use it at your own risk.
To be safe, I'd make a backup copy of your report.asp file first! Hope this helps.
Original Sub DoReport:
Sub DoReport%><table width="100%" cellpadding="8"><tr valign="top"> <td colspan=2 nowrap class="PageHeader"><%=WebReport.Report.Title%><br><font size=2><%=WebReport.Report.SubTitle%></font></td><% If Printable <> "T" AND Printable <> "Y" Then %> <td align=right><a href="<%=URL%>&Printable=TRUE"><img src="/NetPerfMon/images/Button.Printable.gif" border=0></a></td><% End If %></tr><tr valign="top"> <td colspan=2> <% If Len(WebReport.LastError)>0 Then Response.Write(WebReport.LastError) Else WebReport.OutputReport End If %> </td></tr></table><%End sub%>
Modified Sub DoReport:
Sub DoReport%><table width="100%" cellpadding="8"><tr valign="top"> <td colspan=2 nowrap class="PageHeader"><%=WebReport.Report.Title%><br><font size=2><%=WebReport.Report.SubTitle%></font></td><% If Printable <> "T" AND Printable <> "Y" Then %> <td align=right><a href="<%=URL%>&Printable=TRUE"><img src="/NetPerfMon/images/Button.Printable.gif" border=0></a></td><td align=right><a href="<%=URL%>&Printable=TRUE&dataformat=XLS"><img src="/NetPerfMon/images/Button.RawData.gif" border=0></a></td><% End If %></tr><tr valign="top"> <td colspan=2> <% If Len(WebReport.LastError)>0 Then Response.Write(WebReport.LastError) Else WebReport.OutputReport End If %> </td></tr></table><%End sub
The Administrator Guide has a section on exporting reports, beginning on page 171:
Orion Report Writer gives you the ability to present your created reports in a variety of different, industry-standard formats. The following formats (and extensions) are currently supported:•Comma-delimited (*.csv, *.cdf)•Text (*.txt)•HTML (*.htm, *.html)•MIME HTML, with embedded images (*.mhtml)•Excel spreadsheet (*.xls)•Adobe PDF (*.pdf)•Image (*.gif)The following procedure presents the steps required to export an open report from Orion Report Writer into any of the previously listed formats.To export a report from Report Writer:1. Select a report to export by clicking any of the following:•Select a report from the file tree in the left pane•File > Open to open an existing report•File > New Report to create a new report.2. Select File > Export and then click the format in which you want to export your report.3. Check the fields in your open report that you want to export into the selected format, and then click OK.4. Select a location to save your file.5. Provide a File name, and then click Save.
Thank you for your valuable answer.
Hi EZakes,is it also possible to export the data from the webconsole to e.g. Excel.Greetings,Gerjan
Not directly, as you can from the Report Writer.
In the web console, schedule the report to be sent by e-mail, and then you can copy/paste from the e-mail into Excel.
Actually, you can do this. Log in to the Orion web site. Generate a report, and append the fiollowing to the end of the URL:
&dataformat=excel
This will open the file in Excel as long as Excel is installed on the server. You can also open a report in Word. Just repolace the word Excel with Word.
Adobe PDF (*.pdf)
What I'd like to know is when is PDF coming to the web console and Report Scheduler using &dataformat=pdf via the url and Printable Version button?
Kweise,Thanks a lot!!! this was exactly what i needed.Again happy mamangement created!!
Greetings,Gerjan
It is on the list to do, but not in the next version
When will Excel get added as an export option like PDF. We have had several releases now and Excel is still not an option
julian,
You probably already know but I thought I would post it for others, you can add &dataformat=xls to the url for any web report.
Hi.
yes thanks for the feedback. Am aware of the optino to add, just that I would like to schedule reports to out Excel automatically which makes life a little easier for us. Seem this function has been a long time coming so wanted an update.
Appreciate your response however. Julian
