I am new to Solarwind.
Please help me to do the following
In Appinsight, how do I add a node a node.
Hello Moderator,
I have not received any response for my query.
Is my question not visible to every one ?
It is. Sometimes it take some time to get a response depending on the time you posted and the complexity of the question.
Can you share the India contact number for technical support.
Regards
Archana Sahu
All contact information is available at the link below, though the easiest method is to open a case online.
Adding a Node in Orion is fairly simple and straightforward and outlined in the Administrator's Guide in the following section.
Hi please assist me for the below question.
I am trying to create a report with graph/charts that shows me below metric in a single report .
Does Sam has a provision to show the below parameters in a summary format in a single report.?
CPU
Blocking
Memory
PLE
Yes, this can be accomplished by creating a customer report using the Web Based Report Writer. [Settings -> Manage Reports -> Create New Report]. You will likely be using the Custom Table in your report, and possibly the Custom Chart.
