I'm trying to export the switchport map output in any format - HTML, GIF, CSV, Excel, anything, but I'm finding that it is not possible and the option to do so is greyed out.
How do I install an export method?
Installing version 9.2 seemed to do the trick!
I can now export. Great!
try clicking on Map Ports first in the right hand corner....
Thanks for replying, Mark, but why would I try to export an empty dataset? :PAfter a successful switch map I am unable to export to any format as the export list I have seen in previous Engineers -GIF, Jpeg, CSV, Excel, is empty. "No export methods defined"
Publish to web gives "Run-time error '340': Control array element '3' doesn't exist" as soon as I choose the option.
try doing a "Repair" from the add/remove- something with the install is missing.
By that do I understand you to mean from "add/Remove Programs" in the ControlPanel ?
1. did that work?2. I see the same symptom after an upgrade to 8.5.1 and service packs.Is there a global fix to this?For me - these symptoms are in IP Address Mapper.
Yes, from the add/remove programs (then you will see the Repair"option)-
What exact error are you seeing and for which version of the Toolset?
Mark,
It's V8 and given that I'm entiltled to V9, I think I'll upgrade before commenting again.Its sitting on the same box as our Orion 8.5.1.
I hope that's not an issue.Mike
