Trying to install a demo of Log Manager and the configuration wizard is saying that it has detected an "unsupported version of SQL server". My SQL server is MS SQL 2017. What gives?
That's entirely possible. From looking at the build number you provided earlier (Microsoft SQL Server 2016 (RTM-GDR) (KB4019088) - 13.0.1742.0 (X64)) it looks like you are running SQL Server 2016, without SP1. Log Manager requires SP1 to be installed. Once you upgrade your SQL Server to SP1, you should no longer see that warning message during the install.
SQL 2017 is supported so you shouldn't be blocked due to an unsupported version during the install. Would you mind posting a screenshot and I can advise on next steps? Thanks!
Thanks. Would you mind also providing a screenshot from your SQL Server to show exactly which version you are running? Steps available here.
I clearly don't understand what is going on here. The installed version of SQL is 2017, but here is what it is reporting:
Microsoft SQL Server 2016 (RTM-GDR) (KB4019088) - 13.0.1742.0 (X64) Jul 5 2017 23:41:17 Copyright (c) Microsoft Corporation Standard Edition (64-bit) on Windows Server 2016 Standard 6.3 <X64> (Build 14393: ) (Hypervisor)
That's a strange one alright. Could you try running the 'sqllocaldb i'command via the SQLLocalDB.exe utility. It should be located in your SQL install path, e.g. C:\Program Files\Microsoft SQL Server\130\Tools\Binn\SqlLocalDB.exe
I don't seem to have that in my directory:
I also don't see it in the '140\Tools\Binn' or the equivalent directory in 'Program Files (x86)'. What has my sys admin done to me?
