Mike... this is something I've gone over and over with support; the admin guide needs to be re-written because the steps are in some cases wrong or not needed. Here's what I had to do post v9...
Are you using Firefox or IE? If you are using IE, try adding the website to the Trusted Sites list and also reset the trusted sites list to the Default Level.
Thx to aLTeReGo and SamuelB who clearly know more about server authentication than someone who can rarely spell BGP. Domain membership of the server and trusted sites did it...
Happy to help. I'm glad to hear you're up and running.
check your link you use to open the website and see if it has /login at the end of the link.
remove it if it does and then the domian login should take over.
I am trying to get Windows pass through to work but am running into issues. We are runniong 9.1 SP3.
I followed the steps in the admin guide. I made the chnages to the IIS service on the Orion Server. (unchecked anon, check Windows security, applied)
I then ran the config wiz for the website portion. All went well. Now when I log into the Orion website, the guide says I should be able to add a new user, Domain\user.
When I go to add my domain account, it wont let me continue without entering a password? This should not be the case?
Also, if I ever do get this working, will I be able to apply view limitations on the pass through accounts? There are only about 20 users, but they are split in groups of 5 each, and each group is set in Orion to only see thier particular custom property nodes.
Any help would be greatly appreciated.
skierjmh,
This is great information. I will make sure that the documentation is updated for the next release. Meanwhile, we will get this into the release notes.
I will also forward your suggestion about 'if exists' for the custom.config file to Denny and the dev lead.
Michael
Could you give me any further detail on these steps? In step 1, what SP3 are you referring to?
On step 3, where are these permissions you're changing?
In appendix F (Configuring Automatic Login) of the Oct 15 2008 version of the Orion NPM Administrator Guide in the "Using Windows Pass-through Security" (p.294), available on the website, does not contain the step skierjmh is referring to. I would suggest you use this guide (www.solarwinds.com/.../OrionAdministratorGuide.pdf) for your procedure.
To answer your questions, I'm rather sure the sp3 is in reference to Orion NPM version 9.1 SP3 and the permissions are file system permissions on the Solarwinds folder in the inetpub folder. It is not clear to me why write/modify permissions need to be granted, and then taken away. You should not need to grant them.
I detailed the permission changes in another post. It's the permissions on the website through the IIS management snap in.
The SP3 thing is from a long time ago back in the 8.x days, step one does not really apply anymore. What I was encountering that required the user permission changes, was that standard users did not have permissions to access the web folder. I have not upgraded to 9.1 yet, this issue is still around in 9.0.
