Hi all!!!
Anybody knows how add Node Thresholds on view?
Users without admins rights can't edit nodes, but they needed to see thresholds.
hey,
this should do the job:
create a custom query resource paste the SWQL:
select t.name as Alerting_Thresholds,t.level1value AS Warning,t.level2value AS CricitalFROM Orion.Thresholds t INNER JOIN orion.nodes n ON n.nodeid = t.InstanceId Where t.name IN('Nodes.Stats.CpuLoad','Nodes.Stats.ResponseTime','Nodes.Stats.PercentMemoryUsed','Nodes.Stats.PercentLoss') AND (n.nodeID = ${NodeID})
Extra:
i tried to get a case statement to work to change the names but it wasnt playing ball
if your interested or if any one knows why this doesn't work please hit me up:
select case t.name when 'Nodes.Stats.CpuLoad' then 'CPU' when 'Nodes.Stats.ResponseTime' then 'ResponseTime' when 'Nodes.Stats.PercentMemoryUsed' then 'PercentMemoryUsed'when 'Nodes.Stats.PercentLoss' then 'PercentLoss'END as Alerting_Thresholds,n.nodeid,t.level1value AS Warning,t.level2value AS CricitalFROM Orion.Thresholds t INNER JOIN orion.nodes n ON n.nodeid = t.InstanceId Where t.name IN('Nodes.Stats.CpuLoad','Nodes.Stats.ResponseTime','Nodes.Stats.PercentMemoryUsed','Nodes.Stats.PercentLoss') AND (n.nodeID = ${NodeID})
hope that helps
hey, try this:
Thanks.
But I need this
I think the gauges on the Vital stats tab show the thresholds.
It looks like what i need.
This query works fine in SWQL Studio, but this query doesn't work on NodeDetails page.
Anybody knows how filter by current Node?
In SWQL Studio ${NodeID} shows thresholds for all nodes.
But in web query failed.
Agh I think I know the problem lol you need to use the custom query resource on the node details page and paste the query in that should work let me know if you if that works
It's my fault. It's all good. Will think later on the second request. Thank you!
