I think the answer is no. I searched the web IF and the DB and found nothing that would allow it.
Someone please confirm / deny this.
TIA
Chris
The UnDP's use the same polling interval as the Default Node Statistics Poll Interval... I think. This is set on at a global level but can be modified at a per-node level.
Byrona, you are correct. UnDP's use the same interval as the node's statistics polling interval.
The UnDP polling interval is based on the Job Engine which is every 5 minutes and is not customizable.
This has been a high feature request and hope to be able to have the ability to modify it soon.
Umm, we have two different answers from two different SWStaff members. Can I please get a clarification on this so that we are sure?
Casey is correct
Awesome, thanks Brandon!
