I was wondering which SQL query would be useful to query on that database to get some kind of health indication, does anybody know?
Which version of SQL are you using for your Orion database, and what types of health indicators are you looking for? APM ships with several different SQL monitors, but it would be helpful to know exactly what you're trying to do.
-Craig
We are running SQL Server 2008 Enterprise
I actually dont even really know what I am looking for, for one I would just like to pull anything just to get the response time so i can see if or when the database is slow. as we can also get a return value with the sql user experience monitor, some kind of health indicator would be nice also (something like ms per transaction, seconds since last write operation in table X to see if Orion has lost the database connection once again, etc.)
any suggestions Craig?
Hello Questionario,You can use for example:
SELECT DATEDIFF(second, [KeepAlive], GETDATE())FROM [Engines]WHERE [ServerType] = 'Primary'
Engines table [KeepAlive] should be updated every two seconds by Orion so if above query returns value greater than 2, there may be an issue with database connection from Orion.
Thanks Jiri, thats what I was looking for but I am wondering...
Will this alert when custom pollers polling stopped as well as "normal" Orion polling stopped? Because we have had issues with stopped polling for a long time now and we were told that you are polling in two different ways which is why usually only the "normal" polling is affected. or will this only alert if both of them stop?
KeepAlive value is updated by "Standard poller" which is used for polling nodes data through SNMP/ICMP. If only APM polling stops, this value is still updated by standard poller so you won't notice that.
To check if APM polling works you can try:
SELECT TOP 1 DATEDIFF(second, [TimeStamp], GETUTCDATE())FROM [APM_CurrentApplicationStatus]ORDER BY [TimeStamp] DESC
This gives you number of seconds from last application update. If you know that your lowest polling frequency is 1 minute, you can check this value to see if it is greater than 60 and polling hangs. To prevent false alerts I would check for higher value, I would add job timeout to value to handle long running jobs. Default job timeout is 5 minutes so if you test for 360 seconds, you can be quite sure that polling hangs if value is higher.
Here is what I am using
Polling Completion:(percentage of how much is actually getting polled compared to how much is trying to get polled)
SELECT PollingCompletion from NetPerfMon..Engines where IP=${IP}
Last Network Performance Monitor Update:(Minutes since last sync of netperfmon data)
Select DATEDIFF(n,KeepAlive,GETDATE()) From NetPerfMon..Engines where IP=${IP}
Last Syslog Update:(Minutes since last sync of syslog data)
Select DATEDIFF(n,SysLogKeepAlive,GETDATE()) From NetPerfMon..Engines where IP=${IP}
Last Trap Update:(Minutes since last sync of trap data)
Select DATEDIFF(n,TrapsKeepAlive,GETDATE()) From NetPerfMon..Engines where IP=${IP}
am I correct that these monitors wont actually alert if the connection to the database is lost as the advanced alert engine relies on the database to alert?
Is there any way to >alert< if those monitors go down or rather if the database connection is lost?
You could create a job in your database to run every 5 mins, run those queries, and email out if conditions are met, or use another monitoring software like nagios to monitor Orion.
We use Nagios for monitoring other things around here so I monitor Orion with Nagios and Nagios is monitored by Orion.
well, we actually want to get away from exactly that. The strategy was to consolidate to only one monitoring tool but this one thing is really keeping us from that goal...
If you have Kiwi you can use a combination of that and the Solarwinds Event Log Agent to e-mail you when specified events (like an Orion service shutting down or recording of alert errors ) occur.
doesnt work for us... too many errors on the solarwinds server for that :P
also the main issue why orion stops alarming for us is that it loses the connection to the database...
and last but not least... we could monitor it with OpManager even but I am trying to get rid of OpManager :P
