I have seen a few posts about Solarwinds not working with Cisco's new XR software. I have not seen an official answer about this on any of the threads. Does anyone know if this is currently being addressed?
Jamie
Jamie,
We are all in the same boat on this one.... Out of 8 priority fixes for VNQM 4.2 Solarwinds laid out back in early April, this was number 7. They seem to be waiting until their product loses much of its relevance in the Cisco network arena to address this one unfortunately. They actual ranked making prettier zoom-in graphs over fixing this issue .
Hold the goat very still so they can sneak up behind it
It's very true IPSLA support in VNQM doesn't catch up latest & greatest Cisco IOS versions (and variants). Sadly, the implementation of the newly released devices and IPSLA is complex and and we will focus on that once we release SIP trunk capacity and call monitoring for VoIP. The IPSLA support is essence of VNQM, I know it and I hear you guys you need that. I can tell you the better IPSLA support is something we already researched and we're ready to work on for the future of VNQM.
Does anybody know which Cisco IOS versions are working with the present IPSLA from Solarwinds?
We were using 122-33.SRE8 config and IPSLA worked fine with that. We upgraded to Cisco 9001 XR over the summer, and now we don't have anything.
Solarwinds and IOS XE = broken VNQM. I have been telling them for a couple years now this was an issue and it has fallen on deaf ears. No priority has been given to keeping this product relevant with modern Cisco networking gear. Good luck
Note that XE and XR are different. I don't know how authoritative this is, but it at least attempts to de-babelize it a little:
https://pokounetwork.wordpress.com/2013/03/02/difference-between-ios-ios-xe-and-ios-xr/
NX-OS is yet another beast based on Linux.
Cisco command syntax is about as standard as dialects of English all over the world.
I have several 3850s running IOS XE version 03.03.05SE that are working with some operations. So the functionality matrix we need to construct must have columns on a spreadsheet showing something like:
model, OS-version, operation, command, push-cfg, manual-cfg, notes
There are some things I cannot push to anything I need to have on VNQM - like UDP VoIP Jitter. They might push to other models, but I don't know. But I can manually configure UDP VoIP Jitter and manually discover it, say, on a 2951/K9 running IOS 15.4(2)T1.
I haven't gotten either UDP or ICMP path echo to work on anything where it will show me historical paths, either pushed or manually configured.
Note that pushing a config has many possible obstacles, especially differences in command syntax and existing operations or misconfigs. The messages that IOS returns are less than useful.
VNQM probably cannot discover all possible configurations from any device, again because of variations in features and syntax. I doubt that SolarWinds has even 1 of every possible device to test with. So I think we need to see the supported operations, commands, models, and versions documented by SolarWinds. I think we can help that, if we can show what we've been able to get working.
=seymour=
cfg\isevastresn.txt
