PLZ ; could any one help me to monitor Java applet .
Have you tried creating a template to monitor the java process using the Real-Time Process Explorer?
What kind of Java Applet are you trying to monitor? Is this something that normally runs within your browser? What is it about this java applet you'd like to monitor?
yes it's java client that runs within a browser.
SAM does not support monitoring of web based java applications. To monitor a Java applet like this you would need to use our Web Performance Monitor.
Long shot, and an old case, but how would you go about monitoring a java app that runs within an interactive session on a windows machine monitored using an agent.
The app is not web based and the only process is java.exe Wanted something a bit more robust to monitor
Yes, aLTeReGo that is the way I managed it in the end.
