I have several 4500's with SUP6-E's and while NCM pulls the installed blades/cards for all other chassis switches it does not seem that this is true for the 4500.
Anyone have any insight into that?
Can you please open a support ticket on this? It may be that the 4500 uses a different MIB for storing blade/card info.
Opening one now.
Mine seems to be working. What are you using to look at this? I just ran the report in NCM and it pulled the cards.
I was just in NCM itself.
Try running the Cisco Card Data report and see what you get. You might want to just try it on one device. Running it on all Cisco devices could take a little longer.
I don't see any 4500's in the report at all no matter how I run it.
