I would appreciate if you can tell me if there is a option to create an alert in WPM Transaction Availability. Want to trigger an alert event after two consecutive failures polls of 5 minutes?
David
Hi David,
Try checking out the link below which contains several guides that might be useful to you.
Search - SolarWinds Worldwide, LLC. Help and Support
Hi Lindsey,
I believe using this option in alert setting "condition must exist for more "x" minutes is right option.
Polling every 5 minutes ....would check this option and make value = 11.
What is your opinion?
That's the logic we use, works fine.
I am working with WPM 2.1 and am having an issue locating this feature under the "I want to Alert On" Drop down menu. Does anyone know if 2.1 has Alerting capabilities for Transactions?
Yes, we had alerting working with WPM 2.1.
What do you have listed in the drop down menu?
Turns out it was a Licensing issue. All good now
