I have been unable to find where credentials can be modified or deleted after you enter them for a device and click save. What am I missing?
You can edit nodes by clicking on the remove nodes from IP SLA. However it doesn't look like you can modify the CLI creds like I thought. They are stored in multiple tables in the database and can be modified manually. You'll need to open a suppor ticket and we can assist with that. We've also added a feature request to be able to modify the CLI creds after they have been entered if you need to update passwords or remove old creds.
Try to edit one of the nodes you have CLI creds assigned to. You should then be able to edit that cred.
There is no edit CLI option on nodes. I seem to be able to create and save new credentials, but can't find a way to change or delete them.
go to IP SLA Settings - Manage Nodes. Select a node you want to edit and then click the Edit button. New window should open allowing you to change the credentials.
What Manage Nodes button in IP SLA Settings?
On the screenshot that hjarriell posted, there is gold ribbon with a link to "Manage IP SLA Nodes". It's difficult to tell but this is a link. When you click this, you can then select a node and modify the credentials.
