what is the "default summary view" for under the edit account?
thjanks
That's the view you see when you click Home on the menu. The default it what we ship. But you can build different summary views for different accounts.
Hmmm. When I edit this Default Summary View to something other than the view chosen for the Home page, the view chosen for the home page loads when I click Home link in the Menu bar.
IS this a bug?
Denny?
I think you need to customize the menu bar to acheive what you want. Scroll to the bottom of the "Select Menu Itmes to add ...Menu Bar" page and click on Add Custom Menu Item and create a Menu button for the view you created. Name it what you wish- Submit and then delete out the previous "Home" menu item.
Thanks Mark. I can certainly do that. But, I still don't understand what the Default Summary View is there for.
For instance, I have a Home Page called "MyHome" and I also have another summary type view called "OtherHome". When the user clicks on the Home link in the menu bar, they are taken to the view listed for the Home Page View.
However, if I designate the OtherHome view as the Default Summary view, when would that view ever be used?
MArk? See what I mean?
