As things stand now in order to run the SolarWinds legacy software Agent we have to relax Apple’s Security & Privacy Gateway policy as well as utilize legacy Java - are there plans to update the agent?
Hi Edwin - yes, are currently working on an update to the Mac agent as part of the next LEM release.
Can you confirm which settings you need to change as part of the Security & Privacy Gateway policy?
Jamie
Jamie,
While the software does require legacy Java, I was mistaken about having to relax Apple gatekeeper settings. If you would prefer, please delete thisthread and I can start a new one.
Would it be possible to test your new client for Macintosh in my environment? Please. Beyond having to install legacy Java, I am also finding this Macintosh client version does not load – or – release the client agent properly, when starting up or shutting down the machine respectively.
Thanks for your help,
Ed
Hi Edwin,
Thanks for the update regarding the Gatekeeper settings.
Unfortunately we aren't in a position to share an updated Mac client at the moment, but I'll be sure to keep you in the loop on progress.
Does the SolarWinds LEM agent run on Mac OS Sierra? The same binary installs on earlier version but on Sierra I keep getting setup is damaged and can't be opened.
Hi Edwin - there is currently an issue with the LEM agent installer on macOS Sierra. As a workaround, do you have the agent installed on a previous version of macOS? You could copy the ContegoSPOP folder from an older version of macOS to Sierra - this will bypass the need for the installer.
Would you mind sending instructions with paths as to where I can find these folders please
