I have downloaded a few of the config change templates and they are imported in what looks like corrupt. There are special characters where I am guessing txt should be.
Hi Darren Rigby,
The template you are referring to was unfortunately stored on thwack as a ZIP file: Change Login Banner - Cisco IOS(The link may be inaccessible to you.)
I have uploaded it unzipped and verified it can be imported into NCM: Change Login Banner - Cisco IOS
I'll make sure the same issue doesn't happen to other templates.
Regards,
Jiri
with a normal editor (vi or notepad or better one's) you can open the ncm-template files and should see something like in the admin guide http://www.solarwinds.com/documentation/orionncm/docs/orionncmadministratorguide.pdf chapter 8.
also if you imported (copied) the templates you can verify the syntax of the template. is it successful?
show an output of this corrupted template.
kind regards,
flo
It looks like the template is an archive (ZIP). Can you please share the download link?
I am using NCM. Shared Config Change Templates on thwack - Select the Template - Import
I too have this issue, this is the first time I have tried to download and import such templates, which I am doing through NCM. Im even using some of the more commonly used ones, such as change banner... and get this error when I try to run:
This config change template cannot be executed because of the following errors:
An error occurred during script parsing. Position: Line 1, Character 3 Error message: no viable alternative at character ' ' Please check script syntax.
Using: Change Login Banner - Cisco IOS
If I edit template, I see the following, and can see what it wont get passed Character 3!!!
PK �k�<�*�  ,Change Login Banner - Cisco IOS.ncm-template�R�n�0 <7R�a�mU�/4u� )@ �#�,a%cSہ>��� �J �>$���l<��m� �K6y� e>~-�2_<�s1 ����$M��Z� �0
ix�Z� �A�� ��s�qG �3ze�<O��� � >Mg� s��ܙͲq^�E�=� � �=�����Ę�1�� =� �r�� >l<n�Jz�=) f��?� d 8� X|k�2� ,?W�U~ 弴
�N5� *�<�P��t ��: [i=�UD��)m
��n�6 � r'Iɥ
$c b ,߯Q�\�,���b�N���?�[L� �d@?��ޝ���O ���Ȳ� l2��퐟������ӓ� �> �a�� ����� �K���D�T��M�|��(F���d+�WԴ 8�
i�:\�㙣 �G@��!� |'ϻo�'M�PK �k�<�*�  , Change Login Banner - Cisco IOS.ncm-templatePK Z�
