I noticed with one of the latest advertisements that you can monitor current connections on VPN appliances from Cisco. How do I go about monitoring the current connections on an ASA? I have upgraded to NPM 9.0 SP1
Withe the "billy bad-a**" Universal Device Poller! It's sweet. Your Orion has to have SNMP access to the ASA.
Thanks that helps. Did you create the defined poller or did you download it from somewhere?
Did anybody ever reply as to where you get that defined poller? Is it something you download and then import into the Universal Device Poller?
Thanks!
Hey, John, if you created that one, it would be fairly slick if you could post it to the Content Sharing Zone.
Defining is the first step in creating a Universal Device Poller. If you already know the OID that you want to poll, provide it in the OID field, and then the Name and Description fields will auto‑fill. If you do not know the OID you want to poll, click Browse MIB Tree, and then either walk or search the MIB tree to find the OID you want to poll.
More detailed steps for each field option can be found here http://www.solarwinds.com/NetPerfMon/SolarWinds/OrionPHUniversalDevicePollerDefine.htm
Well I'm in a Love/Hate relationship with the Universal Device Poller, but I'll upload that one
Here it is:
