I ran into this error. To correct I right clicked on the system manager program and selected run as administrator.
Do you see any Failure Audit in the Security event log?
Running Process Monitor trace could have helped there but it is not supported on Windows 2008 Server.
http://technet.microsoft.com/en-us/sysinternals/bb896645.aspx
When you repaired the installation were you logged under a local admin account?
Do you see any events with further information in the Application, System or SolarWinds.Net Event logs?
Yann
We just did a fesh install of NPM 9.5 SP1 on Windows Server 2008 and I am experiencing this same problem when I attempt to launch the System Manager. I also get the same error when I attempt t launch Monitor Polling Engines under Advanced Features.
Orion is new to our company and we are trying to get this up ASAP so I hope you guys have a fix for this?
Have you opened a support ticket and per Yann post earlier, is there anything in the logs he mentions?
Looked through all of the logs and was unable to find anything. I will try and create a ticket.
Ticket has been opened, thanks.
We are working on some network changes, as soon as I have a chance to try this stuff out I will let you know how it turns out, thanks for the prompt responses!
Instead of completely disabling UAC, aren't there security policy options you can change so that this will work with UAC still enabled?
Well, disabling UAC did the job and it would seem that no other changes were necessary. Thanks for this advice!
I don't think that giving Network Services full admin acces should be necessary and I would stronly recomend against it if at all possible. Wouldn't just Read or even Modify access be enough?
Can a SolarWinds engineer please respond and verify exactly what level of access is required? Considering how much access this system has to our infrastructure I want to take all necessary security precautions and not just give full admin access to solve problems, thanks!
